It is currently Mon Aug 11, 2025 5:14 am
PostPosted: Mon Oct 19, 2009 8:42 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
I am looking for suggestions for a 10" replacement blade for my table saw. I don't know much about them other than there seems to be a lot of parameters ( tooth count, configuration, hook angle, kerf width gaah ) This will be used mostly as a general purpose blade, cross cutting, minimal ripping. Building jigs, necks etc.
thanks
Richard
PostPosted: Mon Oct 19, 2009 9:31 pm
I'd strongly recommend getting more than one blade. I do 90% of my work with a Frued Diablo 24 tooth rip blade and a 60 tooth crosscut. They are affordable, available, well balanced, and durable. The thin plate can vibrate a bit when ripping but you still end up with less waste than with a full 1/8" kerf. A smaller diameter blade will tend to vibrate less but cut slower. The thin kerf also has less resistance and works well on less powerful saws.
If you are really going to limit yourself to one blade, a Budke 40 tooth combo blade is as good as I've seen. I believer that's a Systematic blade.
http://www.chassonguitars.com
PostPosted: Mon Oct 19, 2009 9:45 pm
I use Forrest Woodworker and Woodworker II. The best you can buy. The cut is smooth like it was sanded. A bit pricey but you can have them sharpened by Forrest later...
PostPosted: Tue Oct 20, 2009 7:48 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Hi Todd, is this the Rigid
http://www.ridgid.com/Tools/Polished-Fi ... /index.htm
thanks
Richard
PostPosted: Tue Oct 20, 2009 9:08 am
Agree with most here .. the Diablo 40 tooth is my main shop workhorse. When I need more depth of cut, I have a Forrest WW2 that I got with the saw.
I also have some of the Diablo 24 tooth, older and a little dull from use, I use them to cut aluminum and CF bars - great little blades for the $
PostPosted: Tue Oct 20, 2009 9:41 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
I have the Sawstop ICS I wonder if the 7 1/4 will work with the dado cartridge?
I have to do some digging
Just curious whats the advantage of the smaller blade over the others?
Richard
PostPosted: Tue Oct 20, 2009 9:53 am
First name: Randolph
Last Name: Morris
I'll second the Forest Woodworker ll for all the above reasons. I have tried many of the less expensive blades and liked some of them, but nothing has matched the quality of cut and durability of edge that this one has.
Users browsing this forum: Colin North, Ken Lewis and 43 guests
